I had a local shop bore out my 200 block and rebuild the head. Now that I have the motor back together with new oil pump, bearings, and seals, I noticed a rattle coming from the timing chain cover using my stethoscope. The motor runs fine, with about 25psi oil pressure at idle. The rattle is particularly noticeable at idle and in Park or Neutral. I don't dare drive it for fear of doing more damage. I took off the pan and timing cover and it looks like the timing chain and sprockets are dry. The more I look at it, I can't seem to figure out how the chain gets oil. The top oil passage is capped off, which it should be. Is the oil supposed to flow from the cam and main journals? SMH.
What am I missing?
What am I missing?
