Hey all,
This is a dumb question, but what are your regular maintenace schedules for a 200ci? I've maintaned a newer Chevy truck before, but the newer automobiles have different maintenance times. The tranny fluid was changed about 2K miles ago (3spd manual). New shocks were installed and greased (how often should I grease those and with what?). What else should I grease (pitman arm? other steering components?) I'm guessing the air filter should be changed at every oil change (every 3k miles, faithfully). When should the rear axel fluid be changed? When I got my new one installed (about 2k miles ago, from a 69 or 70 cougar) the guy filled it up. Spark plugs? I'm guessing every 30k - 50k miles? About the oil filter, I've heard you can use a Motorcraft FL-299. Would you have to have a larger oil pan to take advantage of it (IE would their be enough oil in the pan to fill up the extra space the FL-299 has?)? Right now I use the FL-1A, but the summer here is very hot, and any more cooling I can get is better. Thanks for reading...I know it's such a newb post but I had to ask it!
Erik
Erik
