ozconv
I have a '67 Mustang Convertible with the following build:
-200 six, essentially stock short block rebuild (+0.030) but with ARP fasteners, 0 decked,
double roller timing set, and H264/274 cam with 112 lobe center, advanced 4 degrees.
-Rebuilt OZ-250 head and intake, ported with 1.8" back-cut intake valves and
1.5" exhaust valves, 3 angle valve job, 302 valve springs.
-1.6:1 Adjustable roller tip rockers.
-Classic Inlines header, custom X-pipe, 2" dual exhaust with FlowMaster 40 mufflers.
-Rebuilt post 68 Pre DS1 dizzy with mechanical and vacuum advance, Pertronix Igniter II,
Flame Thrower II coil, Pertronix Wires with 0.045" plug gap (one step colder Autolite 45s).
-Rebuilt 1.02 245cfm Autolite 2100 with manual choke, 53F jets, and throttle plates modified
by drilling 0.040" holes in center of each throttle plate on side of shaft closer to idle screws.
-0.050" compressed Corteco head gasket with 6.5CC stock dished pistons for CR of approximately 9.3:1.
-Higher stall (2800-3000rpm) converter with stock C-4 automatic and trans cooler.
-Stock rear axle with 3.2:1 ratio.
The car idles in gear between 800-900 rpm and about 1400-1500 rpm in park.
Vacuum idling in gear moves between 6-8" and between 14-15" idling in park.
Vacuum when cruising at 45-50 on level surface is about 15".
Under heavy acceleration (close to WOT), vacuum drops to about 3".
When coasting vacuum increases to about 17".
Base timing was set to 18deg at 750 rpm with vacuum advance plugged.
Distributer reluctor set to allow 20deg of mechanical advance max and the lighter spring has been
replaced with the lower tension MR. gasket spring.
Using a dial back timing light with the vacuum still plugged I got the following measurements:
750rpm 18deg
1000rpm 18deg
1500rpm 23deg
2000rpm 28deg
2500rpm 33deg
3000rpm 33deg (not sure why the advance isn't continuing to 38deg max.)
I originally drilled the carb throttle plates to get the engine to stay running below 1200 rpm but I
think it may now be running either too lean at idle or has too much advance at idle (I am using manifold
vacuum since it will stall in gear with only 18deg (best vacuum at 25-30deg). In park with manifold
vacuum the timing is about 40deg at 1500rpm. The balancer is brand new and I have verified TDC.
I suspect a lean or too much timing condition because the engine seems to be running a little hot.
I have a new aluminum water pump, 180deg T-stat, 2-row aluminum radiator with overflow tank, 6 blade mechanical fan,
and a custom aluminum fan shroud fabbed from a universal kit. Fan is about 1" from the radiator and is about
75% of the way into the shroud. Temperatuer measurements with an IR gun are 190-200F taken at various
locations on the cylinder head. One area (topside of #3&4 exhaust port), however, is much hotter.
The head is an OZ 250 2V and the paint on the top side of the siamesed 3&4 exhaust ports has been burning off.
Temperatures at this location are as high as 470F. I don't believe there is any coolant in this area of the
head so I would expect it to be higher but is this too high? I do not have a port divider but do have a CI header.
Plugs still look brand new (white with no coloring or deposits at all making me suspect lean idle).
Driveability isn't too bad with the following exceptions:
1. Idle "hunts" a little bit when stopped at a light for too long. This could just be the cam, or maybe since the vacuum
is fluctuating between 6-8", the power valve might be coming off and on (not sure what PV rating is).
2. Car accelerates well up to about 50mph but seems to run out of steam from there up to 65-70 when trying to
merge on to the highway.
3. At about 2800rpm, the exhaust stops sounding good and starts to sound like a very loud trumpet or kazoo (buzzy).
I'm guessing this might just be the way 6s are but wanted to ask since I am not sure how to recognize "pinging".
Could this also be caused if the timing isn't advancing enough?
I have the following questions:
1. Do these head temperatures seem too high?
2. Could the flattness at 50mph (approx.2700rpm) be do to timing. Should I bend the larger spring tab on the distributer
to bring the mechanical advance in sooner?
3. Should I go to a bigger carb? (1.14 or 1.23 I have both available). I have read that the larger throttle
plates of the 1.23 may allow me to get a better idle without drilling since they don't need to be open as much at idle
and I may not have to open into the transfer slots or drill.
4. What kind of performance should I expect from this build? Is it even possible for this build to spin the tires at a light
(tires are P235/60 R14)? The cam is rated from 2400-6200 so the reduction/loss of acceleration/power above 50 (2700rpm)
is troubling. When I started the engine for the first time (winter), it seemed to be too rich (fouled plugs). Now it
seems lean (summer). Changes (not all at once but in this order) since then included adding the exhaust, removal and
reinstall of head to have checked for cracks (slightly thicker Corteco gasket used instead of Felpro when reinstalled), retarding cam
from 6 degrees advanced (106) to 4 degrees advanced (108), drilling of throttle plates, changing jets (48F to 53F), and
colder Autolite 45 plugs.
Any help/advice would be greatly appreciated.
750rpm 18deg
1000rpm 18deg
1500rpm 23deg
2000rpm 28deg
2500rpm 33deg
