I try my luck again here in the economy forum as well, as I didn't get any response in the main forum:
Recently I saw this David Vizard video, where he talks about setting your idle up for minimum fuel consumption (starts at around 25:00):
He talks about air-fuel-ratios at around 15:1 at idle...
Has anyone done his method before? (air/fuel mixture for MINIMUM vacuum, then adjusting timing for MAXIMUM vacuum --> results in lean mixture with high timing)
Any thoughts on that method? Has anyone tried it? Does it affect general fuel consumption noticeably?
