Good deal! . . If there is enough room to rotate the distributor body, you can in leu of removing it. If you want the vacuum can facing just-so then removal and re-keying will be necessary. How did you determine it's off? Late timing?Got the new head gasket installed and it seems to be holding. I had the engine running for about 20 minutes. I still have the same issue with it not staying running at idle however.... I found that I am a tooth or two off on the distributor. I was able to figure that out with a vacuum gauge hooked up to the intake manifold. I plan on pulling the distributor tomorrow and setting it correctly. Fingers crossed.
Lou,You've generally been following a good diagnostic path but it just hasn't led you to the problem. I'm going to jump outside the box and relay a couple of thoughts that have been running around in the back of my mind.
Was the engine running properly on the original carburetor and intake manifold? Or did you install the carb & manifold as part of the rebuild?
Have you thoroughly checked for vacuum leaks at the intake manifold to cylinder head connection? That's a big problem area, especially with aftermarket aluminum manifolds. I have heard of problems, specifically, with current versions of the Clifford manifold where owners have had to have them resurfaced.
With the distributor set at 30 degrees advance, is your vacuum gauge still reading low and showing late timing? If so, is there any possibility that your timing chain might be a tooth off?
Keep us posted with what you find.
Lou Manglass
Frank,Adding to the above- the damper timing mark may be off. . Late timing or lean mixture will often produce an intake backfire. when it's stumbling at idle, or during working the throttle, does it cough-back in the intake? If so then lean and/or late valve and/or ignition timing is cause.
If all of this was caused by the carb change, go back to the other one!
10-4. It doesn't really matter if it's off, technically. If in doubt use a piston-stop to verify true TDC and mark the damper accordingly. Also verifying TDC will give you an accurate benchmark for judging the valve timing. Hang in there! These projects seem to stretch out into eternity, like they were in a different time-realm. Feel like I'm never going to complete my current project. An engine "refresh" has turned into a full-blow costly overhaul with a never-ending list of small tweaks and changes! LOLFrank,
Funny I just thought of the damper being off as well. I am in to deep to go back now to the original, since it did not run very well after the rebuild..... but I will have to keep that in mind.
Thank you for the encouragement, I really need that right now. I have been second guessing myself constantly with the Mallory distributor and the Weber. Going from one to the other in a never ending cycle of not accomplishing anything, and ending up thinking I should never touch an engine/car again, when it all may come down to someone else's mistake.10-4. It doesn't really matter if it's off, technically. If in doubt use a piston-stop to verify true TDC and mark the damper accordingly. Also verifying TDC will give you an accurate benchmark for judging the valve timing. Hang in there! These projects seem to stretch out into eternity, like they were in a different time-realm. Feel like I'm never going to complete my current project. An engine "refresh" has turned into a full-blow costly overhaul with a never-ending list of small tweaks and changes! LOL
Thank you Lou. I did not even think of resetting it like that.As I recall, that happens when the timing marks are lined up in traditional fashion. Bring the crankshaft around one turn to TDC again and see if the timing marks line up with the 12 links as in the service manual. If they do, just reset the distributor to #1. Number one should be piston at TDC, valves closed, and rotor pointing at #1.
Lou Manglass
When the engine is on TDC after the exhaust stroke, both valves are actually still open a few thousands. When at TDC compression, they're fully closed. This may help figure which TDC you're on.Continued fun times with the timing. I rotated the crank one full turn with #1 TDC and the marks lined up (12 pins in between the dots) and the valves were closed... however.... I am now on the wrong stroke. I verified this by turning the motor and seeing which valve on #1 opened. The intake opened instead of the exhaust. If I was TDC on the compression stroke the next valve to open would be the exhaust. I am kicking myself for not verify this before I put the timing cover and pulley back on. Live and learn, and at least gaskets are cheap.
Correct, the intake valve opened. Also for the matter of rotating the motor in the correct direction.... I am orientated at the front bumper looking at the windshield, I turn the motor clockwise.When the engine is on TDC after the exhaust stroke, both valves are actually still open a few thousands. When at TDC compression, they're fully closed. This may help figure which TDC you're on.
So you're saying with the timing marks aligned, as you rotated the engine the intake valve opened? Verify you're rotating the correct direction. If rotation is correct it's at TDC on the overlap stroke, in which case the marks should not be aligned.
