- I picked up a 1978 200 a while ago, for no other purpose other than I was bored and needed a road-trip to New Jersey.
- The head has been cleaned and no cracks found. It is sitting on a shelf, partially pocket ported ... (for sale soon)
- The block has not been inspected yet. It is sitting on an engine stand. Assume it's good and can be bored.
- Also assume it's going in my 65 Mustang Coupe. My HP goal is... about 400ish
- Reply with your suggestions/ideas on the Carb/EFI, Ignition, Pistons, Cam, AL Head?, Tranny, Reardiff, Exhaust, Turbo???
- Upvote the replies you like, downvote the ones you don't (up/down arrows on the right of the replies).
- Let's have some fun with this!
Added Google Sheet Feb 9, 2020 for P/Ns and Purchasing Dept. Progress...
200 Built By Committee
BOM Seq,Order By Date,Part Desc,Part Num,Vendor,SuggestedBy,ItemURL,Notes,Contact,Email,QuoteNum,QuoteDate,QtyOrdered,Price,Total,Date Ordered,Date Received,Date Delta Days 10,BLOCK RELATED 10.1,200CID Block D8BE,D8BE,Craigslist...,Craigslist Bought,1,$80.00,$80.00 10.11,3/1/2021,Dual Roller Tim...
Mostly Decided:
- Holley Super Sniper 4150 650HP PART# PART# 550-520 - https://www.holley.com/products/fue...sniper_efi/sniper_4bbl_tbi_kits/parts/550-520
- Sniper ignition, etc
- VI AL Head #10269 Ported - https://www.vintageinlines.com/product-page/deposit-only-aluminum-head-package
- Extended Valve Stems +.30 - re note to Matt @ VI stem add +.30 to length as default
- SI
- Manley
- 1300909705/177210 BW Airwerks Turbo S300SX-E 8378 61.44mm T4 .88 AR Journal bearing
- F38-Black-14.5psi - Tial F38 38mm Wastegate Black 14.5psi
- QBOV-Black-11psi-AL - Tial Q BOV 50mm 11psi
- Camshaft - Solid-Lifter Cam CompCams Card 68362
- Lifters - Oil Hole Solid Lifters CompCams SKU 817-12
- Roller Rockers - RAU - F-44RA & F-44RRA? - http://rockerarms.com/pages/rollerfordcad.html
- Adjustable Timing Gear Set - PART# JPP-200-DRC - https://www.vintageinlines.com/product-page/dual-roller-timing-chain-set-170-200ci
- Connecting Rods - Pauter Engineering FOR-235-565-1248F
- Custom forged 2618 alloy pistons - http://racetecpistons.com/
- Equal Length Header/T4 Collector
- Harmonic Balancer / Damper
- http://www.atiracing.com/contact/contactati.htm
- B-H-J - Spoke with Chris, good conversation
- Fluidamper contacted - nope
- ATI - too much normal stuff to do custom.
- Oil Pump
- Contacting Pauter on oil pump mods.
- 250CID Pump, Adapter and drive from D2S Racing Products Inc. ( @drag-200stang )
- Oil Pan
- Canton?
- Modify stock pan, develop windage kit
Added Jan 29,2021 7PM
Vendors Contacted/Emailed:
Magnum Machine Inc.
https://www.magnummachineincorporated.com
Magnum Machine Inc.
921 Business Park Dr
Chesapeake, VA 23320
Telephone: (757) 424-1440
FAX: (757) 424-6210
Owner says- "No prob, I like the oddball builds"
Rocker Arms Unlimited - https://rockerarms.com
16575 Clear Creek Rd.
Redding, CA. 96001
Tel: 530-242-1316
Fax: 530-242-1332
Email: rockerarms@rockerarms.com
re: @bubba22349 's suggestion on roller rocker availability, made in usa
Pauter Machine - https://pauter.com
Don Pauter
367 Zenith Street
Chula Vista, CA 91911
Tel: 619-422-5384
Fax: 619-422-1924
Email: info@pauter.com
Custom Connecting Rods - FOR-235-565-1248F
And oil pumps...
https://pauter.com/parts/oil-pumps/
contacting about HV 200 oil pump mods.
RaceTec Pistons - https://RaceTecPistons.com
Randy Gillis
15681 Computer Lane
Huntington Beach, Ca 92649
Tel: 714-903-4362
Fax: 714-891-0190
CAA Racing Products/Protohawk (torque-plates/other engineering)
https://www.protohawk.com/ https://ccaracing.com/
Michael Gallo
- offered to sanity check our torque plate. because... no one wants to wreck a chunk of stock
- Makes insert bushings too: https://ccaracing.com/engine-block-tooling/
