rommaster2
Ok well I have a leaking rear pan gasket and I have changed the oil pan gasket once before and it still leaks from the same area. Basically it leaks down the back of the engine but it only gets on the front side of the divider plate between tranny and engine never on the back side. Along with that my clutch doesn't ever slip so its not getting oil on it. This is why i believe it to be a rear pan gasket and not a rear main as the rear main should leak on the other side of the divider plate where the flywheel and everything is right?
Well basically I was wondering if there are any suggestions you have to help make sure i get it right? can i use RTV to hold the rubber gaskets in? is there a good way to make sure it all stays in? keep in mind i'm doing this with the engine in the car so i can't flip the motor upside down.
Trying to get this fixed soon as i have to add half a quart every three days. Leaks while sitting but not while driving unless overfilled.
