62goldenrodvan
Ok, Can any one tell me how much timing is too much?
The motor is 204" ford six with the fspp aluminum head clifford header 2.25" exhaust dura spark II msd and a custom intake I made with three 44 idf webers 264 csc and all the whammy shit.
My Question is if the timing is 14 int 20 in the dist totaling 34 deg with the vac distconnected how much timing will the motor see?
With the vac connected @ 3000 rpm my dial back light is telling me 54 deg. yeah 54 deg.
So when every one says 32-36 deg is that really total timing or does the vac advance over lap centifical advance when the rpms are low? and the weights are not all the way against the stops?
At this point I have 14 initial 20 in the dist and 20 more with the vacuum advance hooked up.
Any info,
Thanks,
Kevin.
Any info,
Thanks,
Kevin.
