That’s a bute! Really-really neet setup! I’ve been doing some research and found a few kits that should be able to be cobbled together to use for our Offy setup. See links below.
The price might be prohibitive (shipping from Australia) but the concept is spot on. I’d like to find a hex-rod and hex-heim joint setup stateside, then buy all the bits and pieces separately, unless somebody is making a kit.
that looks amazing, i didn't go with 3 ict's because i think that it was designed to work with a larger carb in the center since it has a larger bore, i have seen a few people on the forum running 1101's as the center and holley 1904's for secondary's so i thought i would try it with ict's, i chose ict's because the linkage arm is adjustable. i did have to mill the taller carb adapter to match the others thickness then fill the old linkage mounting hole, drill a new hole and tap it, to get it to work properly
