Howdy Guys,
In the past couple of months I have only one time had it where the car ran just like it was supposed to. It was a magical moment. It idles perfectly, it did everything it was supposedto. Then magically the leak came back. I'm running out of ideas here. It seems to me, it's leaking on the idle mixture screw side but yet, the gaskets aren't wet, i determined this from spraying starter fluid. I have replaced the power valve cover gasket and nothing changes (the cover was sanded flat by the way) Any ideas?
This is an Autolite 2100 1.08. The throttle shaft is a little on the loose side.
The exact situation is, I'm running very large jets for my 200 (dual 56s) and it still runs lean. At idle its fine but anything above that and it slowly starts to run worse. The wideband starts showing me 15.5-16.5, sometimes more and erratic, when in neutral, revving it and holding steady. When I rev it up to about 3500 it comes down a bit, to about 13.5. When cruising around town it surges then on the highway she runs a little richer than it should (probably from the larger jets). Obviously this is a leak of some sort but what?? Or is the carb just trashed?
Thanks guys,
Ryan
Thanks guys,
Ryan
