This has got me confused, maybe someone here knows what I'm doing wrong. Car is a 61 Falcon, 144/auto/manual choke. Rebuilt the 1 brl Holley awhile back, due to it leaking and wouldn't run with no choke. Got that rebuilt and it ran great, but still had to run the choke 1/4 way out. Open it up and the car would shudder and instantly die. So I drove it awhile with the choke at 1/4, car would crank right up, idle, ran smooth,etc. Well I've been trying to figure out why it wouldn't run with the choke off so I checked for vacuum leaks. No leaks anywere, checked all lines with a vaccum pump. As for the carb I've sprayed it with WD-40 and Either, and no leaks around it either. Only thing I found wrong was the vaccum advance was no good. Replaced that, car ran the same as it had before, no weaker no stronger. After that I checked the timing and dwell. Dwell was 69 and timing was 6 degrees with vaccum advance unhooked and plugged. So I set the Dwell to 40 and bumped the timing to 10 degrees. Hooked it all back up set the idle speed and tried it. Still wouldn't run with the choke off, and had lost "alot" of power. Didn't crank as easy either. So I wound the fast idle screw all the way tight (runs wide open unless the choke is off) and the car runs without the choke now and has more power than ever, but now it sounds like it has a cam in it and dies when I stop. Now what?!?! Sorry for the long post, but I'm out of ideas.
