I have a '78 200 head that I am going to pull to have it milled to raise the CR up to about 9:1 I'll hog off on my mill and then let the automotive machine shop do the final cut. W/ only about 65K miles on the head, it is not really in need of being rebuilt but I figure since it is off, I might as well have it rebuilt. I presume the cast iron valve guides on the head are integrally cast in place - correct? So does the machine shop bore the old guides out and them press in new bronze ones? I am planning on using teflon or vespel valve seals so I want to turn the end of the guides in my lathe (for retaining the seals) prior to the machine shop installing the guides.
Another question - anyone machined out the cast iron guides and pressed in the bronze ones themselves? Not that I am consiering doing this but I do have a mill.
