As suggested by Bill and others previously, you might pull the valve cover and visually inspect the valve stem seals...again as suggested, first making sure they are there...
EDIT: Here's a pic drag200-stang posted on another thread up here (you can see the upside down rubber 'umbrellas' behind the springs...
If they're there, what kind of shape are they in (i.e. cracked,broken,fragged)?...did you shave the head, deck the block or otherwise alter the rocker/pushrod setup that could have damaged the seals?
A quick dirty test might be to drizzle some oil over a suspect cylinder(s)' valve(s)' stem(s) right where the rocker tip contacts the tip of the vavle stem (while running, with the valve cover off...it will be messy) and see if it generates some good puffs out the tail pipe.
And as powerband mentioned earlier, what type of
pvc system are you running, and is it routed correctly? Didn't notice where you commented on that earlier.
After that I'd have to start asking the 'hard' questions Bill posed...what was the condition of the hone, smooth?...did you mic it, or check for eveness/roundness? Where did you source your .060 over pistons? What type of rings did you go with? Could the rings have been installed out of order, upside down, or gapped incorrectly? Good luck
