Below are many of the common C4 Transmission Codes for the 1967 and newer Ford Models these will all have the better Select Shift Valve Bodies. Most of them will have a Column Shift except for those from a Mustang or Cougar - those will all have a Floor Shifter there are exceptions though. Also of note is that the 1970 and up transmissions also have the best in the Factory improvements.
There were also some of the later C4's that had a Manual Shift Arm that could work for either...​
You do not have permission to view the full content of this article. Log in or register now.
