How to adjust your valves properly
First, you need to determine if you have solid lifters or hydraulic lifters. Solid lifters were commonly used on the early 144/170ci motors, while hydraulic lifters were used on the later 144/170ci and all 200/250ci engines. However, this is only a rule of thumb and may vary depending on the model type. For example; a '64 Falcon 170ci came with hydraulic lifters, while the '64 Ranchero 170ci had solid lifters. If your not sure...
