One of the most common problems with the small six is blown header gaskets and/or exhaust leaks. However they can be minimized by following proper installation procedures. The use of locking bolts may help, but even then, leaks can and will occur if you don't torque the header flange bolts (or studs) properly. We also prefer studs over bolts, but that's our personal preference. Bolts will work just as well. The use of a high quality gasket is also very important.
