The Duraspark II distributor is hard to beat as a triggering devise for an electronic ignition system. Coupled with either the stock ignition box or an aftermarket control box (such as as the Dyna Module or MSD-6A) it is a tough, readily available, reliable distributor.
Ford began using electronic ignitions in 1973 and introduced the Duraspark II system in 1976. The biggest change, apart...​
You do not have permission to view the full content of this article. Log in or register now.
  • Like
Reactions: marquis83
