Before You Touch the Carb​
The secret to understanding the critical nature of Weber carb setup is the idle circuit — referred to as the low-speed circuit by Weber. This circuit is responsible for 80% of the driving operation. A properly set up Weber should give an improvement in fuel economy over most factory carbs, along with significant performance gains.
Before adjusting or re-jetting the carb, sort out the supporting systems first.
Step 1 — Check for...​
You do not have permission to view the full content of this article. Log in or register now.
