I've got my spare head apart and am contemplating sbc 1.94/1.60's. I've read that they must be cut down. Does anyone have the measurements of the stock 1.94? My spare (ford) head 1.78 intake valves appear to be 5/16 X approximately 4-11/16". It just so happens that I have a dozen or so sbc 1.94's, :roll: but they're a bit snowbound right now, so I can't get my mitts on them.
My old FI Chebby heads also have performance springs that were designed for much more cam than my 300 will ever see. Are they also interchangeable?
The reason I ask is that I have a small (1 ex. valve) problem that has launched me into the possibility of rebuilding my spare head, at a time when I just sunk $$$ into a beautification project. Having tha valves and springs lying around :roll: , I thought I might as well look into using them for a budget valve job.
Back in November, there was a post on offset valve guides that led to a discussion of optimal port sizing. With my spare head stripped, I find that the rectagular intake port appears to be 1.625 x 1.1875 or 1.93 sq. inches. The optimal flow for the stock 1.78 intake requires a port area of 2.02 sq. inches. If I did my math correctly (BIG if), that (2.02) translates to 1.657 x 1.2195, or (-).016 - per side of the intake rectangle. Does that sound right?
For the 1.94's, I come up with a 1.8 x 1.3625 (-.0875 per side) to get the optimal flow port size of 2.45.
The stock flow bowl diameter (1.64) is actually at optimum in one direction, but slightly restricted in the other. It doesn't appear that much porting is needed to optimize the 300 head for flow with the stock intake valve...? I realize that there is a good deal to be gained from smoothing out some of the casting marks & such - especially on the short side radius near the valve.
I'm undecided on going to 1.94's - it sounds like the benefit might be marginal for my usage. My personal redline is ABSOLUTELY 4500 rpm, and I usually shift at 2500. I RARELY exceed 3500 rpm. With a 4x4 truck cam designed for improved torque in the idle - 4500 rpm, would the 1.94's be beneficial? This is a 5,000 lb 4x4 mule!
Sorry to unleash so many questions at once, but I've been doing my homework and it just happened...
Comments, corrections or suggestions would be welcomed!
broncr
broncr
