Well, I've finally put together various parts from about 3 differant carbs to try and get this thing to run halfway decent until I do an engine swap (plan to use differant carb then). The lid flange is warped, so I had to use 2 gaskets to get it to seal. I lowered the float the same amount as the thickness of the gasket so it's at the correct level when assembled.
The car seems to be too rich- I'm getting soot on the ground during startup/warmup, but the manual choke is fully open (not hooked up) and I have adjusted the mixture screw for smoothest idle when the engine is warm. I have to feather the throttle for a few minutes when it's cold to keep the engine running, so I'm thinking the accelerator pump is too rich and needs adjusting, although I've already set it to factory specs. How do I lean out the "squirt"? Shorten the pump rod, or lengthen it? I don't think my landlady likes the black spots on the driveway :roll:
Thanks,
Sedanman
Thanks,
Sedanman
