Cool Ch**y brother. Be sure and tell me how it all goes now!
Make sure your TV valve cable is perfect too. A200-R4 is an ace pice of gear if you do it right. In a light car like yours, it is a winner.
I considered bolting one up to my old 3.3 GM in-line Vauxhall engine aslate as 1994.
I did get this blurb from a 1988 August Hot Rod magazine (Page 67, but article is from 66 to 69, if you can track it down). It applies to the 700 R4, not the 200 R4. You can be fairly sure there is no difference in the systems, though the part numbers may be different, or may have changed some thru the years.
In order to maximise gas mileage potential, top speed, and overall transmission longevity on street aplications, the lock-up converter feauture should be retained, at least in high gear. On TH700-R4s built prior to 1984, the lock-up was controlled by the transmissions valve body. With these early units, no electrical mods are required (however, the early units do not have the durability of the later models). Starting in 1984, GM began using the main computer on some models to control the converter lock-up.By 1986, lock-up on virtually all applications was computer controlled. In order to lock up late-model 700 transmission converters on noncomputer retrofit applications, you will need to buy the switches and connectors and wire the system according to the B&M guidelines.
There is a lovely picture of the TV cable set up, and I used this to do my Holley cable design on my 84 Falco. But there was also a picture of the wire-up for R4's which don't have the earlier lock-up on transmission valve body.The following should be noted:-
Items to shop for:
*Procure the stock TORQUE CONVERTOR CLUTCH CONNECTOR and HARNESS, if you haven't done already.
*Buy a B&M HIGH GEAR SWITCH.
*You must wire the lock-up feature into the EXISTING STOP LAMP wires for safety, so that brake application unlocks theconvertor. To do this, you need #25524846 (modern switch that bolts onto for 65 El Camnios, anyway. Yours will most likely be the same). This is a no longer a two pin number, but a four prong number with two in the normal spot, and two out the side.
Instructions:
In regards to the
torque converter clutch connector itself, it said
A, the existing purple wire, is linked to the B&M High gear switch.
B, the existing blue wire, is taped off.
the
C wire remains blank,
use the existing brown wire to
D,
The existing purple wire goes from
the B&M controller (a trans switch) to the lower back prong of the four pin #25524846. The B&M piece is just a two pin device.
At the four pin
#25524846, the back prong A is purple wired, the prong B is wired to the 12v ignition "hot" terminal, and the existing stop lamp wired go in and out to the top prongs.
There ya go. Hope you can cross check all this.
