Having a GREAT time trying to find bearings for a 56 f-350- anyone know if F3 or other model bearings will cross over? Would really like to replace them all- its been sitting for a few years.
On that F-350 the fronts it should for sure be for the years 1953 to 1956 here is a listing on the front bearings to get you started. On the year axel it might depend on if you have duel or single rear wheels. They used the Timken Rockwell rear axels and the years should be 1953 to 1962. Good luck
Wow how fast things can change, their listing had the Timken bearing numbers listed for the front wheel hubs for the inner and outer bearings that was this afternoon when I posted the link. Guess I should of wrote down the part numbers when I first saw them. Since then I have also confirmed that the rear axels used were the Timken Rockwell units and were they were used from 1953 to 1962. Do you happen to have a NAPA auto parts near you? If not they do have an online listing for the 1956 F-350 wheel bearings (see below link). Good luck
