I've been working on the assumption that the head on my 144 is the one that's been on it since it rolled off the line but now I'm wondering if it's been swapped.
Rebuilt the engine 3000 miles ago and been very happy with it. I think it has plenty of power, runs smooth, etc. I decided to do a compression test just to make sure everything is even and it is... at 105psi on each cylinder +/-2ish psi. So that works out to a whopping 7.5:1 compression.
Code on the head is C3DE-6090-G. This is a 63 144 with a block code of C3DE-6015-E. I figured this is the right head based on the codes but was I wrong? I know these had a steel shim head gasket originally and the new ones are thicker but would that really drop the comp. ratio from 8.7 to 7.5? I'm guessing this is probably what's going on but I'm surprised it changed this much. The head was decked enough to flatten it out and the block was bored .040 over, deck wasn't touched.
I also know the shop manual states these came in low compression variants (my vin tag says this should be an 8.7 head though), what was the compression ratio with the low comp. head?
Anyway, the car runs too nice to do anything about it now, this is really just to satisfy my own curiosity.
