1967 Straight 6 Issues!
I am now at a complete loss and require some outside assistance. Needless to say, the car is a 1967 with a 200. Being a work-in-progress, I had garaged the car about three to four years ago in perfect running condition. I had replaced the timing chain, most major gaskets, and replaced the stock distributor with MSD 6 Ignition. I was driving the car daily, with the above work done to the engine, for over 2 years without any problems. I then placed the car in the garage and ran the engine every other month...then never turned it over for at least three years.
Four years later and now I decide to get the car running again. I did the following to prepare the engine to be turned over: Changed the oil and antifreeze and drained all of the old gas. Figuring that the car was running perfectly when I parked it in the garage, I assumed that just adding new gas would allow me to drive right out....WRONG!
This is what I have come up with as to the problem at hand: With either the MSD 6 OR the old Stock Ignition system (I kept the old distributor), I cannot get the car to start when I time the engine at TDC (compression stroke on Cylinder 1). If I turn the distributor as far as I can turn counter-clockwise (from TDC), the engine will semi-idle (about a minute or two)and will eventually backfire through the carburetor if I even try to give it any gas.
I have rebuilt the carburetor (Autolite 1100), checked the compression (~86 in each cylinder), checked plug wires, replaced spark plugs, checked and replaced the coil....I am preparing to do a leak down test tomorrow, but I don’t think I need to as the compression seems good enough.
Has anyone out there seen this?!?!?!
Are you sure the distributor was'nt installed 180 degrees out? Its pretty easy to do if you are'nt paying attention.
Just to make sure I was not going crazy, I did try the 180 degree trick and it did not work...
Check your firing order. Also check that each wire is getting spark. Just use a spare spark plug and pull each wire one at a time and put the spare plug on the wire (leaving the other plug in the engine) and see if it arcs.
Also, if it has been 3 years since it was last run, think about a new coil and go back to original dizzy, just to eliminate possibily of the MSD going bad after sitting for so long.
Slade
Slade
I have given this one a shot as well. I placed the original distributor in yestarday with a new coil and wires (all tested OK) and I was receiving a spark from each wire.
What are the chances that the valves could be sticking? Is it possible for a valve to open and close only part way? With the compression, I would assume that could be ruled out....however I have had a few people tell me that this could be a valve related problem.
addo":1jhx707e said:
It is well possible for valves to stick.
If I find this to be the problem tomorrow, does anyone have any suggestion as to the "best" method for fixing this?
I'm guessing fuel pressure, or carb problem (even if just rebuilt), combinded with a timing issue. Check the float level, idle mix, etc. If the dizzy were out 180, it wouldn't even start, much less idle.
