1980 200
If I purchase a 200 from a 1980 Fairmont and the tranny that I get with it is not a C4,will I still be able to use the 200 with my C4 from my 170 out of a 64.5 Mustang?
I want to buy this engine but need to know that I can use the engine>The tranny is not so important.
Any response will be appreciated.
Ponyman,
Maybe.
Look at how you starter is located on you stock block as a reference before you go to look at the Fairmont. Notice how it is above the oilpan seam where the pan attaches to the block
You need to look at the starter location on the Fairmont. If it is below the seam where the oil pan bolts on, your C/4 won't bolt on It has a different, bigger, bellhousing flange on the block.
Ford made a running "empty parts bin" change - that is, when they finally ran out of the high mount starter block, they started using the low mount starter blocks. So it is impossible to say which block is in 79's and 80's without actually looking at the block.
If this enginge doesn't work out for you (big Bell) you might try to get the DSII distributor and ALL of it's wiring and Coil and brain box. The head and carb are save-able too. It is probably a Hex-shaped log head, but it would have bigger ports and valves, hardened seats, and a bigger carb.
So, if the car is going to the crusher, and you can get the parts CHEAPLY, grab them.
Hope it works for you
