probably a 'progressive' 2bbl Weber 32/36 or Holley/Weber 5200 clone licensed from Weber. Also could be bigger Weber 38/38 if engine is built up.
Weber 32/36 DGV Complete Carburetor, New - Pegasus Auto Racing Supplies
The popular dual-throat Weber 32/36 DGV is flexible, easily tunable, and reliable. It is the carburetor of choice for racing classes from IT to Formula Ford.www.pegasusautoracing.com
The 5200 progressive can be a good match for the small block six:
... the progressive 2 barrel carbs' are the pricey Weber 32/36 and Holley/Weber version - H/W5200. The 5200 series progressive is widely available inexpensively having been used on many small 4cyl. engines and V6's thru 70's/80's. Most available "list numbers" or applications' jetting' are for small displacement four cyl's and a lower CFM than the small block six needs . THe 32/36 and 5200 are easily re-jetted though, and if you search here you will find a lot of discussion on getting them tuned for different engine configurations. I've run a H/W5200 from a Capri 2800cc (170cid) V6 application "list#" on a 170 through a simple $15 2X1 adapter for @ 15 years. It yields smooth idle and excellent performance and economy but it took two carbs and help to get there ...
hav e fun
I agree. Nice find! A gentle suggestion: When you get it going, replace the air filter with one with more filter surface area. That one is a high-flow media, and may be sufficient in flow, but the high-flow media filters like K&N do not filter as well as the paper elements. I got rid of a K&N after finding fine dust in the airhorn after a few months of use.I appreciate all of your responses. I bought the engine complete, just pulled from a 65 Mustang. Didn't even notice carb when I bought it. If it is the weber, I got my moneys worth right there.
Yes sir, I serviced it per their instructions, had the pint squirt bottle of red K&N filter oil. . I should edit the above slightly, it was probably a year using the filter, removed it for a metering rod swap and there was dust residue. Very fine, slightly oil-sticky. Obviously a concern for engine internals, but equally unhealthy for carb air bleeds, etc. .Was the filter oiled?
I am also considering a K&N but for me a clean intake is more important than little more flow...
Ok then if you want to know anymore on what Carb that you have then you will need to supply more details. Either find it's Carb ID Numbers, the best way and or take some better very close up pictures of it. Good luck
My bad. .I didn't intend to start a carb air filter thread!! I'm seeking information on the two barrel carburetor on a 1965 Ford 200 ci engine.
