Curseoftheblade
Active member
It was actually pretty easy to get it in there. I ended up using the 250 engine mounts and the 200 engine mount brackets. The 250 is not noticably wider than the 200 at the mounts at least. I'll have to add shims so the 250 mounts and 200 brackets so they seat flush together though. Also, the engine doesn't clear the hood (with the low maverick air cleaner) by maybe 2/3 an inch. I'm going to extend the engine mounts downward and redrill the holes lower to drop it about an inch. I should have room to spare at that point. The fan actually clears the radiator but i may take off a bit from the spacer just a bit to give better clearance. The trans limes need to be rebent due to the lower mounting starter but i don't think much more than that.
