For Sale 200 6-cyl engines
Mike_Senar
Active member
Hello from San Diego,
I have a couple complete 200-6 engines from a big purchase I did some months ago. They turn over and feel o.k. I have no way to start them as of the moment. Selling as cores, but may be 100% o.k. $300.00 ea.
Mike
Mike
Hello,
Are these still available? Do you have any photos?
I am curious as to how much it would cost to ship one to Florida.
Thank you!
Hello,
I did not take any pictures as I figured everyone here knows what one of these look like... I can supply pictures if I had a phone # to send them to. Shipping guess $300.00
Mike
Hello,
I have two left. One is a California 1966 version with all the air injection smog parts still mounted on it. The other one I would need to look at again for you. They turn over and feel like there is good compression, but they are not mounted in a vehicle so I could not (very easily) perform a true compression test on it. I also have two shortblock cores.
Mike
P.S. I would have P.M.'d you, but I apparently do not have permission to do that...?!!
Hello,
Mike
Hey I’m looking for a 200 have any left in out here in Beaumont t and would have no problem coming to pick one up
How do I tell if I have a 144 or the 170 just got a 61 falcon ranchero and trying to figure out what size it is so I can build it a little and put a turbo on it for street driving
Hello,
If I remember correctly, the stroke of the piston changed between a 144 and a 170. Pull a spark plug and stick a solid rod (coat hanger straightened out works) and mark it at the top of stroke and turn over motor by hand and re-mark the wire to realize the stroke of your motor. Check that against the two motor specs.
Mike
Hello,
I still have one, but it is a 1966 unit with the air injection components. Those can be removed and the ports in the head closed off. But, it is not a 100% correct motor for a 1968 b/c of that detail. If you are o.k. with that difference, we could work a deal. It is a good motor! I am in San Diego!
Mike
