turboe farelane":nlbty8p9 said:use a phillips screwdriver (or a drift pin) in a flywheel hole at the starter opening.
turbo_fairlane_200":3490rycq said:there is another method.....
I use a phillips screwdriver (or a drift pin) in a flywheel hole at the starter opening. this can be done with the motor in the car so you don't have to wrestle it on a stand. also works good for torqing flywheel bolts down.
pedal2themetal45":3eioj060 said:#1 is for a manule temp sending unit.
Tim
