Good luck.Have fun.Be safe.
Leo
We always like to look at photos. Congrats on getting your head off!60sMustang":14w8t3sd said:I'd be happy to email some pics if someone is willing to look at them.
60sMustang":rrmyfogf said:So today I got the engine hoist, hooked the hook in the water neck hole on the front of the head, jacked it up a little to put some upward tension on while tapping the log portion of the head with a small sledge hammer. It finally broke free from the block after a couple tries.
The gasket appears to be metal for the most part and has left a paper-like material on both the head and block. It Does not look like it will be easy to clean up for reinstall of the head. Does this sound like the remains of an original gasket possibly?
Any suggestions for preparing the block for the new gasket and removing the leftover gasket material. Its like a paper type material that is over most of the surface of the block. My concern is getting a bunch of it in the antifreeze by falling down in the passages.
Also I'm new to the internal portion of an engine, the pistons have some carbon buildup on them and the head has a lot. A couple of the plugs were black also when I pulled them, I believe from the center cylinders. Is this common or is it maybe running to rich and needs re-jetted in the carb?
Should I try to completely clean the piston tops and block surface and if so what should I use? Don't want to damage anything.
60sMustang":y1qry2te said:Don't know if I'd be comfortable with the "crank it over" method to break it free, but it sounds like it could work also. Anyone else have experience doing this?
Yes, 'bare metal'. U got it Bro!60sMustang":1tjfx837 said:Ya I gave it some thought...which is probably why I chose not to do it. Lol
Can anyone tell me how "clean" the block has to be before reinstalling the head? I have it down to mostly bare metal but there are several spots you can see the outline of the previous gasket still. It's smooth and flat just some leftover paper or adhesive I think. Not sure I can get it any better without sanding it or using a wire wheel. Didn't want to risk damaging the surface. Does it need to be all bare metal?
