The oil pump, driveshaft, and dizzy all have to match. They changed from a 1/4" shaft to a 5/16" shaft around 1965 so unless you change the oil pump on the '68, then no, it wont work.
Post 1965 200s and all 250's use the same distributor, but the 250 has a longer oil pump shaft than the 170/200.
