Hello
I’m very new to engines so bear with me. I have a ‘68 200, unfortunately the head is not in the greatest shape. I’m have been having trouble finding a head at wreckers etc. What I have found is agricultural swathers have the 200 and I can get a 1981-83 200 ci engine (from the casting numbers). From what I have read on the forums everything should bolt on etc after milling to get proper cr. My question is will I still be able to use the 1100 autolite that I have or is the port going to be different size and does that matter? The swather engine has a different type carb with a governor etc. Thank you for your time.
