All Small Six 200 Timing Chain?
InlineMustanger
As previously posted. Lost power on 200. Compression test show significant loss of compression in all cylinders. Dipstick shows no coolant in oil.
Does looking at timing chain as the issue a waste of time or worth the effort?
No definitely recommend. Take a long ratchet with a 13/16 socket & rotate the crankshaft back & forth to see how much play is in the timing chain.
If excessive replace the chain with a full roller chain. Vintage Inlines sells them.
