200ci engine dimensions?
pacer
Could someone please supply me with some engine dimensions? I would like to know the length of the motor from the engine/transmission connection to the front of the water pump and I also need the height of the motor from the lowest point "sump" and the height at the very front of the motor from the oil pan to the valve cover. Also how much do these motors weigh?? I want to make a wood template to see if a 200ci will fit in my project vehicle!! Thanks for your help guys!!!
Anyone? I need help with this!! I need to figure out whether the motor will fit in my project car??
I have never seen that information published on any of the many many threads that I have read. I like yourself thought that by now somebody would have tossed a measuring tape on a motor and got those critical measurements but alas they have not. I cannot help as I don't even have a Ford Six at my house right now.
-ron
the trans is not connected.
23 1/8" tall (edelbrock valve cover)
the block is 31 3/8" long from water pump snout to trans. mating surface
the trans is 30 1/2" long ( C4 auto )
these numbers are guaranteed +/- 1/8" :lol:
the lowest area of the oil pan to the top of the valve cover.
these are close numbers. without a large caliper, it's the best I can do. :wink:
also, you'll need to consider the oil cap. I did not include it in the measurement.
