All Small Six 2V conversion adapter sealing
clochard68
Subscriber
Supporter 2021
Supporter 2022
Supporter 2023
How do you guys seal the aluminum adapter to the log manifold?
With JB Weld, or RTV?
I was wondering, because the different thermal expansion of the aluminum and cast iron would call for a gasket...
Thanks for the answer!
if very hot the thin gasket material works best, where carb is mated, a thicker cork gasket works for iso' . the '74 uses a blow thru a 2X1 and I make the gaskets and use copper spray for sealant - blo-thru hat gasket is a trick' though ...
> and over time all tolerances change...
hav e fun
