I am going from a 1 bbl Holley carb to a 2 bbl and I found a JEG's Remanufactured Holley 2 bbl but it's 500 cfm. I heard that 350 cfm is pretty much the max on a stock (as far as I know) 200? What would happen if the 2 bbl carb was installed?
The reason I said that "as far as I know the engine is stock" was because I took a quick measurement of the bottom of the Intake valves (while they were installed in the head) and I got 1.75 inches. The exhaust and intake valves are less than a 1/4" apart from the side of each of the valves. Could this be stock? Was measuring the valve on the bottom the right place to measure? I seriously doubt that someone put in bigger valves in this engine because 1) its a 1982 Granada Station Wagon and 2) the engine seems like it has been run straight into the ground (nobody but a inline six lover would want to fix it.). Thanks for any help you can give me.
Jamie
Jamie
