66comet202
Hey all,
I'm running ridiculously rich. I put new plugs Saturday, drove 15 miles, and all six plugs were soot black afterwards!
Here's the engine:
Stock 200ci
Autolite 1100
LOM dizzy
Probably 165k miles
I've done the following.
I do have an exhaust leak. I had the entire exhaust replaced a week ago, but it appears the manifold is warped. Will try a second gasket before having it planed.
I use 87 octane and a fuel treatment ( for the water).
Hopefully with the new points and condenser I've installed have made a big difference. I did see a thread here about buying jets from http://www.carburetor-parts.com/. Of course I'll have to take the car apart again to see what size I currently have.
Anyway,
Any help/advice/sarcasm is completely appreciated!
Thanks!
Greg
Here's the engine:
Stock 200ci
Autolite 1100
LOM dizzy
Probably 165k miles
- new plugs
new new wires
new rotor
new cap (What cap are you using on your LOM?)
verified timing at 14* - From what I can tell the damper has not slipped. The groove on the damper within a degree or two of TDC. I checked with spark plug out, piston at the top of the cylinder and the rotor at #1.)
Compression tested out at 160 on #1 and 170 on the rest for the dry test. Haven't done a wet or a leakdown.
Just today I put new points and condenser on so I need to see how that does.
Anyway,
Thanks!
Greg
