The spark plug wires are correctly placed, I have new points, condenser, and distributor cap. I am setting the first spark plug at 6* BTDC, and I am flipping the distributor 180* just to make sure it will be at TDC instead of BDC.[/quote]
this confuses me
to static time simply get the timing mark at zero this is compression stroke TDC(damper and pointer) then open distributor and make sure points are just opening,(Plug fires when points open not close)I use a ohm meter. then make sure rotor button is on the #1 plug wire. Fireing order is __too young too old just right--15-36-24rotating the same direction the button spins. This will have it close enough to crank with ease then use light.
I would also check the fuel filter on a car that sat and make sure you have fuel pressure into the carb bowl- lossen line at carb,aim into cup and spin her over should, pulse strongly. crap will build up in the filter from gas varnish in tank, often will get in carb bowl then clog jets.. also make sure that you don't have cracked insulter where point mount over posts have had this drive me crazy before.
Let us know what you find--love a mystery!
