Lupin,
I think you are letting the cart get before the horse. As others have stated the body needs some serious repairs before you even think about an engine/drivetrain.
You stated that you think somebody had it off the frame and started the restoration; as others have alluded to this is impossible since the mustang is a unibody car and does not have a separate frame. The "U-shaped beams" you mentioned are indeed the frame rails; between those and the roof this is what holds the car together. Right now it is mostly held together by the roof and rocker panels. From one of your pictures it looks like somebody might've replaced at least one of the rocker panels.
What I would do if I were you is before you do anything decide how much the car is worth to you and how motivated you are to fix it. This will give you an idea of your price limit and how much time you are willing to spend to get it drivable.
Then I would start pulling things. Pull the engine, transmission, rearend, suspension, etc. Get it up on jackstands and look over every nook and cranny. Figure out what needs to be replaced and what doesn't. Then spend a good several hours online looking up prices for things to replace. This will give you a rough idea of how much the car needs. If this goes over your previous spending limit, then look for a car in driveable condition.
From looking at it I can tell you it will need at least the following metal repairs just to be driveable:
- part or most of the front and rear framerails
- entire floor
- entire trunk floor
- tail panel
- inner fender walls
In addition to these you will probably want to do the following metal repairs:
- cowl
- quarter panels
- fenders
- wheel wells (inner and/or outer)
This can be done, and I've done it, but it is a considerable investment and requires a lot of dedication on your part. It all comes down to what you're looking for, and if you're just looking for a 6-cyl driver you might want to buy something turnkey and save a lot of money/time. If you do this, though, try to make sure the mustang goes to somebody that is willing to fix it rather than junk it.
Jason
- entire floor
- tail panel
- cowl
- quarter panels
- fenders
Jason
