All Small Six 68 small log head porting [ including preliminary DYNO RESULTS ]
I have very much enjoyed this thread and have reread it at least twice and appreciate the detailed information. If you can get 130 hp from a small log head 200 that is impressive compared to the 80 hp stock from the original dyno test which was great base info. That is a 50 hp, or 63% increase over stock!
On the provided dyno torque numbers are they represented in ft lbs like in the US?
Is your C4 stock? I have read about modifications that give it more of a performance feel such as shift points and firmer shifts.
Looking forward to hearing more.
@bmbm40 Thank you for the kind words. I am glad you got something out of this thread.
Regarding your questions:
The torque numbers are in newton meters (so if you multiply my numbers by 0.738 you get the ft-lbs). Of course the torque numbers are so high in the beginning of the curve because of the torque converter, but it's the torque you feel on the street non the less...
I installed a Transgo shift kit into my C4 for firmer shifts, and you definitely feel it when driving, it shifts a lot quicker now.
I finally ordered a seat cutting tool from ebay and these two Goodson cutters for my new SI 1.75 intake valves.
As soon as I got time I will be installing the bigger valves (I currently have 1.65 standard valves) and will do my best to give them a 30° backcut.
The plan is to NOT unshroud the chamber any more, but I will see once the valves are fitted.
I post this primarily to hold myself accountable to finally getting this modification done, I will keep you updated...
“...post this primarily to hold myself accountable..."
You stole my trick
8^ )
I NEED my friends’n neighbors
On the guides its kind of a catch 22 deal, shorter guides will give you more flow however shorter guides won't last quite as long either, full lenght guides give more valve support against side loads. I think the replacement guides may also be a little bit longer than stock guides were but I haven't measured them in a quite awhile so you might check that out. If you were wanting to go with the shortened the guides don't have them drive the guides down as far into the valve pocket any farther than stock the excess can be cut off at the valve spring seat easier than trying to shorten or shape them in the valve pocket. With the shaft rocker arm assemblely that the 200's and other Ford small six engines have as well your going with the Yella Terella 1.65 roller rockers there shouldn't be as much side loading to the valve guides to cause any extra wear. The compromise position would be to use the full lenght valve guides or even longer than stock and then tapering them in the valve pocket so as to gain as much flow as possible that way. As to the spiral or plain the sprial might allow a little more oil in to lube the guides that can possibly help the longer lasting idea. Are you going to use a PC type valve guide seals?
Yes by all means on grinding out the exhaust port bumps I will always grind them out on any of the A.I.R. Heads and on some engines this can make quite a differance in port flow. As far as grinding around the spark plug I don't bother that area at all this could affect your swirl I only would polish the existing shape along with the rest of the chamber. With the stock size valves I don't see you needing to much unshouding the valves either. If you do unshoud the valves don't use the head gasket opening its 3.820 way to big the stock bore on a 200 is 3.680 thus would create a ledge that would cause turbulence. So scribe the blocks bore size around the heads combustion chamber and see what you have and for sure don't go out past that scribe line so the chamber isn’t any bigger then the bore size around the valves you are unshording, prorbally better is to keep most of the chamber smaller than the bore size, plus the more you grind on the chambers your add to your CC’s and loosing some of your compression.
You Distribitor is a 1968 duel advance with a duel vacuum advance canister these are the best of the older point distributors plus yours has a Protronix Ignitor so its not a bad set up if the center shaft bushings are still in good shape they can be rebuilt and recurved too. Best of luck
Is it possible to flatten the exhaust port bumps on a US '66 small log head without breaking through?
On clochard68’s thread~
Philo:
my thought is: have U ever puta scroll grinder or burr to a head?
Have U seen the profile sketches in Tech Archive (or other) for this head?
“...Is it possible ...” is a tough way to go abt it (as “is it possible?” can geta response of
“anything is possible" - [given time, talent & $]).
Often stating a problem and asking for solutions/help can assist much more than
embedding an answr in the Q.
HTH
