Never use a gasket for any porting...Should have been apparent that there was a divot behind that bump..who ever started the gasket port matching should have his porting license taken away.Interesting photo by a ford six guy.
"78_200_C4 milled his 78 large log head (~62cc) and shaved it 0.060”. Assuming that the milling landed the combustion chamber in the range of 52cc (minus 10cc, linear approach like in the example above).
The calculated static compression ratio with FLAT TOP pistons is 9.63:1 . No ping and runs with cheapest gas."
Edit:My latest 78 200 with the .060 milled head has 78 dished pistons. I don't know how much that will efffect the compession
Ok, that changes things a littleEdit:
A Slivolite catalog claims a 2.220” dia. head recess .085” deep. If this is correct:
Using an online calculator and if I didn't make a mistake the following would be the dish volume on my 78 pistons.
.32901428622148 cubic inches
5.3915781652 CC's
Hi clochard68, in answer to your above question a tighter Quench Distance helps in preventing Detention and will therefore let you run a slightly higher C. R. Generally this ideal Quench Distance is in the .035 to .050 range, in this case less is better with some even going with a Q. D. as tight as .030, as an example a stock 200 six with a Std. Bore has a Piston with a 1.511 Compression Height this sets piston top .019 below the block deck and with a stock steel shim head gasket of .022 we have a pretty good Quench Distance of .041. With today’s thicker comp. head gasket the Q. D. Is much more.@bubba22349 do I understand this right, you mean a higher compression "needs" a narrower quench height? Or would it just "be better" to have one?
I didn't think you implied anything but wasn't sure what I meant.I didn't mean to imply you have ping, I meant if you have dished pistons and therefore your static compression ratio is below 9:1 (if I calculate either with 5cc or your suggested 0.9 ratio, you are below 9:1) it is logical you don't have ping. I am asking for static compression ratios above 9.5:1, where knock/ping is a possibility.
Thank you for the link, that thread from xctasy is basically everything I was looking for (some numbers for orientation! Thanks again!!
Hello gb500,My opinion with a cast iron head is 10:1 is too much. 9.5 max with good fuel
would be ok for normal driver to leave a bit in reserve.
Disclaimer: i'm no ford 6 tuner....but we are talking 50/60 year old chamber shapes /designs, cast iron heads, carb controlled fuel ratios and distributor ignition.
Generally an alloy head over a cast iron is safe for 0.5 extra comp ratio
Yes this is correct, my squish height should be 0.065".and regarding this link - i was referring to on ANY build to set up your quench/squish correctly at 35- 40thou.- ok dont need to be extreme squish and Comp as Falcon 60 was - and his machining was free and knew what he was doing -.machining and tuning -but he details how it helps his engine run well at high comp ratios he was using
if i read your post number 65, above ,you will have 65 thou squish . (19thou piston in the deck plus 45 thou gasket) but you are concentrating on the overall comp ratio
New 200 build is running!
Hi all- Just did an intro over on the other page,and thought I'd let you know what I've been up to. I have a '60 Falcon 2 dr HT with 144/3 spd manual. Too slow for me,so I built a 200. I work in an engine shop,so all machine work was done by me. I used 6cc cast pistons (.040"),decked the...fordsix.com
see if you can track down a 25?thou steel head gasket . they are out there but rare!Yes this is correct, my squish height should be 0.065".
At the moment I have no possibility to deck the block, so I have to work with that deck height. But thank you for the clarification.
Regards, Martin
