garrilla
Active member
bubba22349":1prkumdr said:The first one is easy decodes as the head being cast at the Ford foundry on January 17, 1963 and making it near the end of production of the 223's. I can't make out the numbers and such in the second picture, the other block numbers probally are up under the exhaust manafold or in the indents along the oil pan rails. The third picture is of an aftermarket engine rebuilders tag can't help much with that, but it should give you the details of sizes of the internal rotating assembly. Depending on the code that company used the cranks Rods & Mains "A " may mean that they are .010 / .010 under size, can't read all the numbers on the bore size looks like 3.80? Good luck![]()
Thanks for your input! Does the 4th pic give any clues? When I was searching for a water pump and water neck outlet and gaskets I had several options for a 223.
