adjustable pushrods?
Hi all,
I got a 250 head from mraley that is milled .060 for my 200. My block is not decked. The head comes with a stock adjustable rocker. Will I need to change push rods? The head on the engine now has the non-adustable rocker.
A new cam, lifters, pushrods and timing set is planned for the future but I wanted to go ahead with the head install for now so if I can run it with the original pushrods for now that would be great.
Bob
The non-adjust push-rods are the ball on each end, the adustable rods are
ball on one end and cup on the other. This is what I had when I made
the swap. I had to purchase a new push- rod set.
hope this helps :D
Yes you well need to get adjustable rocker pushrods... As they are different. Non-adjustable pushrods are balled on both ends.. Adjustable rocker pushrods are round on the bottoem end (lifter side) and have cup on the top end for the adjuster screw to sit in.
tim
