Hey guys, I am still chasing my vibration. I have tested the compression on ever cylinder and they are 120 across the board. I replaced the condenser, soil, regapped the plugs, and the points, rebuilt the carb, and rechecked my wiring in the engine bay. All to no avail. I am taking it back to the trans shop where I had it rebuilt so they can check the torque converter and their work over this week. right now I have the vaclve cover off, and I wanted to adjust the valves while I wasn in there. The shop manual is very vague on how to do this. I think that one of the valves is sticking. When I hold a piece of paper behind the exhaust pipe the paper moves with the exhaust like usual and does a pop pop pop every now and then. If I recall right that was a sure bet for a sticking valve, but I figured the compression test would show that, but it didn't. I know that the exhaust manifold is warped where it meets the head, and I have a small leak around the #1 cylinder. Could that cause the bad vibration at higher rpm's? It does it in park or in gear. As the rev's climb the vibration speeds up. Any help would be cool. I'd like to adjust the valves tommorow, so I can button everything up to take it to the tranny shop on Monday.
Jon
Jon
