i modified a oil type air cleaner.i cut the bottom center out and reversed it .then welded it back in in order to get more clearence on top of the carb and hopefully more air flow .i cut the fuzzy part off the top .then got a new element.to fit . my theory is the air comes in thru the 2 inch gap between the lid and the bottom then i used a narrower element to hopefullly get some more air swirl inside the bottom then the air funnels down into the carb .i havent noticed any better mpg but more engine power when i accellerate .and more hill power.
i found the plans on how to do the conversion at fte tech articles.
is there any holes in my theory i would be glad to recieve input
the other reason i built this air cleaner is i couldnt find a stock aircleaner.
thank you
lrd56 a happy dinosaur
thank you
