The way it works....instead of the tube squirting gas down the venturi...the tube is redirected upward and the gas hits the underside of the concave "umbrella" disk. The underside of the disk can have channels going from the center of the disk to the outer edge of the disk.Interesting! sure seems like it would significantly alter the jetting. The design flow through the booster is nearly reversed. Unless I'm seeing the drawing wrong.
No, it's better being posted on your thread, or start a new one.The way it works....instead of the tube squirting gas down the venturi...the tube is redirected upward and the gas hits the underside of the concave "umbrella" disk. The underside of the disk can have channels going from the center of the disk to the outer edge of the disk.
I think the gas would atomize better if the edge of the disk were very thin or razor like.
One type of disk is formed from a mold using Buna-N rubber. Another type of disk is made out of stainless (which I think is a better idea...being able to sharpen the outer edge to razor-like...what the heck do I know lol)
You can download the full patent here if you like:
My thoughts.....this really was used by a few people in the 70's....and after almost all cars were equipped with F.I. and ECMs by 1990....the powers that be decided to release the patent figuring no one would be interested in it.
Heck....I could be wrong...maybe.
I know gas vapor in the carb body is a bad thing (vapor lock)...but gas vapor in the manifold...can't see how that would be bad.
Except for a backfire......where the heck did that manifold and carb go?
I thought about posting this info under the "Carburetor" thread...but didn't want to get laughed off the forum.....yet.
Thanks for the heads up on posting. Not really good on the edict when it comes to forums and not into social media much at all.No, it's better being posted on your thread, or start a new one.
The only thing I can say to it is: in my experience with flowing fluids (extensive- water and air), I would propose that a sharp edge will tear the gas apart less than an edge with a rough lip. As the transition of fuel past the edge of the disk into the airstream occurs, the less "organized" the fuel is at the moment it strikes the air, the better. Coming off the disk in a smooth undisturbed stream vs coming off the disk having to have just tumbled over a lip. The lip seems better for breaking it up. Smooth is for those fancy water fountains. If water fall off the face of a smooth curved surface it stays in a sheet much longer than if it is tumbling when it falls.
The area directly under the traditional booster which feeds fuel acts to pull the fuel outward, increasing mixing and atomization. The disk design- just looking at it- seems less efficient at atomization. . . just surmising. .
No luck with the compression test...thought I could spin the crank with an impact wrench - no go. With all the plugs out it turns by hand like it should. Never tried a C.T. without a flywheel and a starter before. I'll go with my first plan and open her up...48 years old it could probably use a little freshening up.Thanks for the heads up on posting. Not really good on the edict when it comes to forums and not into social media much at all.
As far as the disk edge...one way to find out for sure.
I get what you're saying about smooth for the water fountains....but the downdraft and vacuum might have a different effect.
I'd like to play around with it but won't be getting around to it for some time. I might have to end up selling the house next year.
Not sure where I'd go to but out of ill-inois for sure. Property tax and water/sewer are way too high...just can't afford it here any more.
Thanks for the info with your experiences! I just saw your post today...02/24...sorry for the late reply.ive been using similar process mainly smaller parts.
- make sure your parts don't touch, i melted down a battery that way, normally I use a charger now but it can blow the charger, you might add a fuse.
bolting the electrode can work or sometimes Ill solder a wire to the item, otherwise if its just contact by wrapping the contact gets lost, bubbling stops.
I use baking soda for a scrub down, after or in between, its cheap and cleans nicely.
generally I leave it a few sessions checking back on progress. the parts clean better if they are near to the electrode so moving then about helps.
I lay a plastic basket full of holes, from a berry farm inside a tote bin that isolates my parts from electrodes int he bottom.
be really carful about stainless, you mentioned noxious gasses and Ive read people using stainless for the electrode, thats dangerous, the fumes produced by stainless can be a factor so I wouldn't put anything stainless in the tub. galvanized, not sure.
ive done it using muriatic acid, talk about bad fumes, it works but the stuff is dangerous and very noxious gases come off.. they will rust anything surrounding too. parts also start rusting immediately after they are out of the bath. muriatic acid also eats aluminum
I did do a lot of small parts that way though, it'll remove rust and paint and it leaves the metal etched. id neutralize it with baking soda, warm it with a torch to drive out moisture then use epoxy the epoxy latches onto the deeply etched metal and grabs so it doesn't rust again.
electrolysis seems a lot less dangerous so far as the chemistry involved but it could give off some nasty poisonous vapors
I bought some pickling paste, it is used to remove rust and only commercially available. Its a very strong acid. I do not recommend it. - too hazardous. I put some coated shiny new washers in there and it gave off bad fumes and started getting hot and smoking. probably also giving off nasty chemical vapors.
another method I want to try you can get a cheap setup it connects to a pressure washer and puts sand into the water stream, so it's wet sandblasting the item. you have to contain the debris somehow.
I'm not pulling my engine but thought I might brush on some of that rust inhibitor, maybe paint later but without engine removal. ive been using it with a little brush on places where rust is appearing but I don't have time to do actual bodywork. it seems to still work and the rust seems to not start back up even with no other coating. you are supposed to wash it off after, then paint,, but I've been leaving it, I can just do a few applications, in summer, then I can clean and paint stuff, too cold now. over winter I can still brush a little of it on in rusty places.. it seems ok to do that.. my truck is white so Id get rust stains running down below any rust.. it seems to help to simply brush on some rust converter like on a scratch or rusty bolt head,, and walk away, Ive been using rust check brand. in some spots Il take a knife and get under the paint as the rust is creeping, then just apply the converter.. when its warm and rust is more under control I'll do some spot paint repairs.
my floor developed a hole, I went at it with an angle grinder and sanding disk , roughly removed loose rust, used rust converter, then washed it down and dried, then I used fiberglass but instead of polyester resin, epoxy resin. for my hole I made a stainless plate and bolted that then used fibreglass on top leveled it out, worked fine no more big hole.
I have rusty rims and just had new tires mounted, can I put the whole tire and rim into a electrolysis bath? dismounting and re-balancing is a couple hundred.. I just want to paint the rims, doesn't need to be perfect.
"that engine block looks fantastic !"I noted that there was a similar thread on electrolysis rust removal but it had become locked somehow. the poster seemed to be using zinc in the process and I know it is a less noble metal but I wasn;t sure of the intent of using the zinc. since the thread was old and locked there wasnt; an opportunity there to ask.
I wentintoi fixing a washing machine, they fail due to the spider rotting out by electrolysis its like a giant mercedes sign that ties the stainless drum to the shaft, well it turns out samsung knows this and does it intentionally, so if you own any brand of front load washer with a stainless drum never close the door, that makes it worse. I was suprised that the thing was quite heavy but had turned basically to sand.. boats use blocks of zinc as expendable electrodes to protect other parts from electrolysis due to the seawater which is a great electrolyte. I wasnt; sure why zinc was used in the process of rust removal though..
Ive heard not to use stainless as the vapors are deadly but some writeuos said use stainless. I like using scrap iron sheets then I can use a zipdisk or sanding pad to clean them up.. sheet metal has lots of surface area.
Id put a little warning , be careful you dont short out your parts and electrodes or youll kill your big battery charger by shorting it. this is easy to do accidentally.
Im thinking of building apool made of 2x 4 and plywood lined with plastic so its big enoguh for things like fenders and doors..
I thought I may use 24 V it might go faster.
the work done seems to relate to how close the expendable electrodes are fro the item being cleaned.
I found that wrapping and tying parts caused bad connections , then the proicess stops. I got onto the idea that you can use these common brakets , they are made for hanging wires to hold suspended ceilings, they have a nice little clamp bolt. meant to hold it to the heavy angle iron above the ceiling.. they seemed good to use as connectors.
I also tried soldering my wire to my expendable electrode and that helped to keep it connected.
I've tried it in the past a few times with smaller items and was using baking soda but washing soda may work better.
when I pull my parts and they are blackened i use a rag with baking soda for that, its a good cleaner and it wont hurt the solution since it can be baking soda anyway.
maybe a 20 amp fuse or so can be used in case parts touch so you dont blow a battery charger.
why 12 volts? I thik I have a great big 24 V supply so maybe that will go faster. maybe there is a safe limit but it stands to reason the voltage may relate to the speed.
I came to the realization that many do a great job stripping and then use paint from a rattle bomb or heat paint but its quite thin and the OEM paint was quite thick. I was thinking its actually important if you want the nice paint to last to maybe build it thicker or maybe find pain that is less thinned out than what comes in the rattle cans. It alway looks nice at first. but after all the work it may rust after 5 years if its just a rattle can.
the electrolysis may present some dangers but Ive used muriatic acid and that stuff is completely horrible. other acids work too but the electrolysis wont eat the parent metal .. acid will , and a warning here, acid eats alunimum for breakfast.
body shops do use acid as part of a pint prep ritual so you can get such products.
im also a big fan of using rust amalgamator and have had good results when its something where I want it done fast and over.
From my experience anything that I stripped well and coated with epoxy paint never again rusted,,
l just use whatever color 2 part epoxy I have , and then the rattle can for the color I like.. the engine block might exceed the heat rating of epoxy, so it would be good to check. I think JB weld is good to 600 degrees or so so its ok on engines. maybe different types of epoxy have different properties relating to withstanding higher temps.
a paint I tried and liked a lot was this stainless steel paint, it is a coating you brush it on then cook it. it is heat cured. you need to etch or sandblast blast first.. the stuff had so many warnings. it maybe another discontinued product. I really liked that for rocker covers and ashtrays as it has a nice OEM sort of look, it is not shiny but dull grey and to me looks very OEM. its good for manifolds and exhaust pipe parts. with those they stink when you fire up but the then it can harden from the heat of the part itself.
I dont know if the product is still available.
i guess we will see what happens wiht the EPA and restrictions like those mentioned above and access to offshore parts as there are big changes happening now. I think we are all waiting to see whats in store next. or whats not in the store.. I think right now everyone is reeling back a knotch with expendatures ,, for me anyway and some others, its good time for some of those jobs that take more time than expensive parts. Let the chips fall where they may I guess.. I'm pretty resourceful and I have the benefit of having that 1930's save everything, you might need it, 1930's philosophy drummed into me.. I feel like its very similar now.
If new cars go up as drastically as expected maybe we are all in a similar position being able to fix up older stuff.. I see it as somewhat of a benefit to those who have that type of skillset.
