Hey all, finally had time to pull my motor and and start the process of a full rebuild.  Here’s the current list of parts…
Aluminum head serial #026
Yella Terra 1:65 roller rockers
Double timing chain
Holley 2300 sniper
Holley hyper spark distributor and coil pack
Schneider cams 262-70h cam
I’m going with flat top pistons but don’t know if I need to bore the block yet.  T5 conversion.  A bunch of other miscellaneous parts.  I do have a couple questions though.
Should I upgrade the radiator from factory?  The original one looks to be in good shape and doesn’t have much crud in it.  Do they flow enough for a mild build?
The alternator that’s in the car doesn’t have any tags on it except “tested to 70 amps”.  It is not a single wire alternator.  Will I have issues running the Holley components with this?   I’m sure I’ll I’ll have a lot more questions as I continue on.  Calling this week to get in to the machine shop for the block work.  Decking, cam bearings etc.   It has been about 5 years in the making for parts acquisition and time to do it but I’m glad it’s finally started!
Seen your post about the radiator. I have a 67 Mustang vert 200/c4 . I run a small log head with a 2300 Sniper & Hyperspark . I installed a Paxton on it about .2 years ago . Before the Paxton install i ran a new copper & brass oem type radiator  and everything was fine .
  During the Paxton install i put a brand new alumn Radiator in, a new flow cooler water pump along with a flex blade fan .
  Have to really keep an eye on it now . In slow or stopped traffic it will heat up sometimes badley .   Planning on installing pretty much every thing on my eng that you listed other than the rebuild .  Been about a 6 year acculation of parts .When I do I plan on going back to the oem style radiator .
   You put your timeing #'s in the handheld try 24 degrees for your idle . My motor did'nt like the factory 12 degrees at all for idle setting.
 Put 24 in & it idles smooth now .
 You will like that 2300 if you get it sorted out . Adds a good bit of power .  For what it's worth get an intank  efi fuel pump . The inline pumps that.come with the Sniper kits are a problem waiting to happen .
 Another suggestion is to install an electronic fuel pressure gauge inside where you can monitor your fuel pressure , a pressure gauge under the hood is pretty useless .
 Another for what it's worth , be on the lookout out for a Paxton set up for your 200 ,that thing is killer paired up with a 2300 Sniper . My vert runs like it has a v8 in now . Even pushing everything thru that small log head .
