Air filter
Titleist16
Does anybody know where I can get a 14" air filter. I've been to all the local parts stores and the biggest they have a 13 1/4".
Does it really matter?
Do you want the whole assembly, or just the element?
I just need the element. I have a 14" open air assembly for a 1bbl that I customized to work on my 2bbl. I already went and picked one up so i'm good to go. Thanks
Get a 14 inch from K&N they're expensive but you'll never need to replace it you just wash it out, let it dry and put some filter oil on it and your good to go. where did you get your 14 inch air cleaner base for a 1 bbl?
Titleist16":1ronfrl5 said:
I just need the element. Apparently STP sells a 14" filter at Autozone
Let's see how good my memory is after 5 years - it was a SA-136, right?
1) K&N's flow great but don't filter worth a sh*t. They let everything through shy of small stones.
You would never ever in your life have to clean it, because it would never get enough build-up to hurt flow (on such a small engine as your six). A 14" paper of a 200 engine would probably be good for close to 10 years, too.
