I'm thinking about installing an Air:Fuel meter so that I can better tune her. I understand that the O2 sensor needs to be installed in the exhaust (right?) and then wired to the gauge in the car. I was told that you drill a hole in the exhaust, weld in a fitting, then screw in the sensor. Sound right? Does it matter where in the exhaust the O2 sensor is installed? I'm running dual out headers with an H pipe down the line a bit right before the mufflers.
Is there an easier way to do this than cutting and welding, etc?
Can someone recommend a good combo (gauge and sensor)?
Thanks all.
Thanks all.
