airbag code 32
One. Tell your friend politely to get ***. See or ring his Ford dealer NOW.
Two. Make him read this.
If you plan to work on your airbag system, exercise extreme caution. Personal injury may result if you accidently deploy an air bag. The airbag system is live all of the time - it is not switched on and off by the key. There are also backup power supplies.
Never attach a self-powered test light to any part of an airbag system. If you want to work on the system, acquire and review a manual that covers servicing of the system. Examples are the Air Bag System Diagnosis training manual from Ford..
Make sure your head is still attached. Don't muck around with an air bag..ever.
PS. From "AIR BAG DIAGNOSTIC MONITOR FAULT CODE PRIORITY TABLE"
Priority Code Component/Fault Description
Highest -- No Air Bag Lamp - Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor
| -- Continuous Air Bag Lamp - Diagnostic Monitor Disconnected or Inoperative
| 12 Low Battery Voltage
| 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
| 21 Safing Sensor - Not Mounted on Vehicle Properly
| 22 Safing Sensor Output Circuit - Shorted to Battery Voltage
| 23 Safing Sensor Input Feed/Return Circuit Open
| 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
| 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
| 33 Pin 7 Not Grounded at Diagnostic Monitor
| 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
| 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
| 41 Crash Sensor Circuit - High Resistance or Open
| 44 RH Crash Sensor - Not Mounted to Vehicle Properly
| 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
| 46 LH Crash Sensor - Not Mounted to Vehicle Properly
| 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
| 52 Backup Power Supply - Voltage Boost Fault
| 53 Internal Diagnostic Monitor Fault
Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected
thanks xecute
could it maybe something to do with the wiring as his crusie control does not work either but the radio controls work. he has changed the steering wheel and this did not help, which you would think if the airbag was faulty it would have worked?
well if ford have to fix it i guess that is what he will have to do.
thanks Aaron
Aaron,
try something simple first.
Yes be careful.
Try, diconnecting the battery positive cable and leaving off for around a minute.
Cant hurt, may fix problem.
May not but worth a try.
You will have to reinstall the radio code afterwards.
Noel.
it is an au 2 and all this started after replacing the battery, all fuse are good so i guess he will be of to the dealer
An AU repair manual will tell you how to reset the airbag
On a EL there is a diagnosis plug in the fuse box to reset the airbag you simply bridge a wire from terminal M (airbag memory clear) to terminal B (earth)
You will hear five beeps after the beeps disconect the wire and turn the ignition off
